Configure an ACE to filter IPv6 routed packets only.
The ACL exists.
The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the Ipv6Routed tab.
- Select Insert.
- In AclId, type the appropriate ACL ID.
- In AceId, type the appropriate ACE ID.
- Select RoutedOnly.
- Select Insert.
Ipv6Routed Field Descriptions
The following table describes values on the Ipv6Routed tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
RoutedOnly |
Specifies the match for IPv6 routed packets only. |
